Smoked Corners
Old Jan 27, 2007 | 09:57 PM
Kage's Avatar
Cool
Originally Posted by mycamaroSS
also, when i get mine, how do you put em in
Here ya go my brotha........
Old Jan 28, 2007 | 03:43 AM
The Guz's Avatar
Originally Posted by UAZ28SS
Those are the same ones I have. Do you have any issues with moisture getting in them after you wash the car? mine do, and it's pissin' me off!
I sealed them up before I put them on. Put a thick bead of silicone around the lense as well as where the bulb goes in. Have had no moisture after doing this. My previous clear corners were ruined because of them leaking.
Old Jan 28, 2007 | 07:40 AM
RedRallyeZ's Avatar
slid them in from underneath, the only problem is trying to slide the old ones out. About 1/8th of an inch sticks out too far on the sides of the lenses so it hits up against the seam where the bumper connects to the front fascia, ao that took a little manuvering ot get out.
Old Jan 28, 2007 | 09:12 AM
mycamaroSS's Avatar
^alright, so it sucks doing it lol
Old Jan 28, 2007 | 09:32 AM
f50nut's Avatar
No just take the headlight out. It's one bolt and then they slide to the left (or right) and pull out. It takes about 10 minutes each side to change, and I put a thin layer of silicone over the mounting surface for the bulb - never had moisture in there.
Old Jan 28, 2007 | 04:13 PM
UAZ28SS's Avatar
Like he said... pull the headlight out from the top... MUCH easier to change them that way.
Thanks for the tip... I'll do that to mine when it's out from under the cover for the winter!
Old Jan 28, 2007 | 08:48 PM
mycamaroSS's Avatar
how do you take the headlights out
Old Jan 28, 2007 | 08:50 PM
mycamaroSS's Avatar
ok i just bought these
Old Feb 16, 2009 | 11:13 PM
blk97z28's Avatar
How do you do this on LT1'S? i AM going blacked out markers. Thanks guys .
Old Feb 17, 2009 | 12:38 AM
fbodyrs96's Avatar
form the bottom..
Old Feb 17, 2009 | 08:54 AM
blk97z28's Avatar
Originally Posted by fbodyrs96
form the bottom..
that is what I thought, thanks
