Trans am headlights!
why not just do a retrofit from like blackbird? I think pop up headlights are iconic on our cars. the motors are not that bad as long as you install them correctly and make sure the motors don't come loose.
You will have to investigate why the driver's side is not functioning. See if you can deploy it using the manual/raise screw behind the headlight.
