!wire mod, where to get grommet?
Old Feb 2, 2007 | 12:26 AM
pHEnomIC's Avatar
Default !wire mod, where to get grommet?
I did the wiremod in the spring and i just sanded the metal down nice and cleared it to prevent rust. It looks pretty good but i need a grommet to finish it up. Where did you guys go to get your grommets or what did you use? I cant think up anything and ive been to a few home depots and lowes and they tell me they dont have anything for me.
Old Feb 2, 2007 | 01:42 AM
parbreak's Avatar
You can get grommets in all kinds of sizes from McMaster-Carr.
Old Feb 4, 2007 | 02:16 PM
pHEnomIC's Avatar
Any stores that may have something? What exactly should i ask for? All ive found so far is plastic grommets for desks.
Old Feb 4, 2007 | 03:16 PM
SS LS1's Avatar
My wire hole is not on a flat surface but rather on a surface with a few angles, therefore a traditional round grommet would be loose or pucker up at some point so I just made my own.
I used a length of thick vacuum hose that I cut a slit along the side of it, run around the wire opening, then super glue in place.
Old Feb 4, 2007 | 03:42 PM
LILWS6's Avatar
^ i agree i would do this
Old Feb 4, 2007 | 06:43 PM
pHEnomIC's Avatar
Alright sweet, my hole is cut in the exact same spot as you so that would look very good.
Old Mar 31, 2007 | 05:58 PM
Blakbird24's Avatar
Restricted User
My method is similiar to what SS LS1 did. I used the thick foam-type electrical tape and just ran it around the hole, folding half on the engine compartment side of the hole and half on the wheel well side. No glue needed, the adhesive on that tape is nuts. Both methods work fine with holes on flat or angled surfaces, and both come out looking great.
