LS1 to LT1 laillights?
Old Feb 7, 2007 | 01:40 AM
01PewterDropTop's Avatar
Default LS1 to LT1 laillights?
I want to put some LT1 taillights on my 01 and i want them to lightup like LT1 lights all the way acrost. I heard it was possable.
Thanks for any help
Old Feb 7, 2007 | 02:13 AM
Kevano26's Avatar
marijuana?.... but why?
Old Feb 7, 2007 | 02:16 AM
kaos_'s Avatar
lol
i'm pretty sure you just take the ls1 lights out and pop the lt1 lights in. aren't they installed the same?
Old Feb 7, 2007 | 06:38 AM
Duffster's Avatar
The LT1 lights have two separate bulbs that light when braking. The LS1s only have one. It would require tapping the two bulbs together, and by doing this, when you hit the turnsignals, both would also light up. If it didn't give your electrical system fits.
Whitebird???
Old Feb 10, 2007 | 09:27 PM
Umm weird i heard you use 93-97 taillight harnesses and you need to swich to duel filement "i cant spell SORRY" lights.
The LT1 light houseings should just swap right in i heard one of the lights will be a tight fit. but it will light up the same as a LS1 still only on the ends. I want it to light up red under the reverse section also, and get brighter when you hit the brakes.
Old Feb 10, 2007 | 09:29 PM
Its not a Bird if thats what you are thinking. The new "LS1" bird lights are a lot nicer then the lt1 style .
And yes marijuana!!
Old Feb 10, 2007 | 09:49 PM
Y2K Pewter SS's Avatar
You mean like this?
Old Feb 10, 2007 | 10:45 PM
kornfreak_401's Avatar
the "SS" is a HORRIBLE CLONE
Old Feb 10, 2007 | 10:49 PM
If you are referring to the pic I posted, thats a true SS, its one of my best friends.
Old Feb 10, 2007 | 11:30 PM
Breathtaker's Avatar
Originally Posted by Y2K Pewter SS
Nice and original, but I wouldn't do it on my car tho.
Tell your friend to get the chrome Z28 exhaust tips, it would look MUCH better.
Old Feb 10, 2007 | 11:37 PM
blackops22's Avatar
Agreed.
Old Feb 10, 2007 | 11:45 PM
http://www.fquick.com/S-friggin-S
There, you guys can tell him yourselves
Old Feb 11, 2007 | 04:23 PM
LS1DER's Avatar
I just did this swap this weekend. Whitebird00 was a big help. If you use the LS1 harness the brake and turn signal lights will be seperate. With the LT1 harness the brake and turn signal lights are the same. I used the LT1 harness and bulbs. The LT1 lights are 4 wire instead of 5 wire. All you have to do to get it to work is splice the blue wire coming from the brake switch to terminal P of the 11 pin connector underneath the drivers side dash. If you are going to use the LT1 harness you can pm me for all the details. With the LS1 harness you just have to simply swap light housings. It was very easy to do once whitebird00 showed me the way.
Old Feb 11, 2007 | 04:27 PM
bdr_ws6's Avatar
Looking at that silver car^^^^ I can see why you Camaro guys want to swap to the LT1 lights, they look A LOT better. Just IMO, which I do like the LT1 Trans Am tail lights better than the LS1s too.
Old Feb 11, 2007 | 07:35 PM
purple98haz28's Avatar
i want to do this so bad
