Interior Light Question
On the door just it just shine down from above the handle?
thanks
http://www.keliente.com/****.htm -Headlight
To change the door LED, you only need to remove the small trim piece around the door handle.
1. The trim comes out with two screws, one on the side of the handle, and one right above the ****. Remove those, and then pop the trim piece out. It doesn't need to come out all of the way.
2. The bulb holders are verbatim to the ones in the HVAC. Twist it out, remove the bulb, and insert the new one. Once again you may run into the bulb being stuck good...get all of the pieces out of it.
3. Turn the lights on and observe. If it doesn't light up, turn the new LED bulb around.
4. Reinstall trim piece and screws, and repeat on the other side.
