Polishing Question
Old Apr 2, 2007 | 06:48 PM
FireBreathingChicken's Avatar
Default Polishing Question
When you sand, do you go in the same direction for all the grits. Or do you go in a different direction for each grit. Or do you do a circular motion? Thanks for any help. I'm trying to find the best way to sand these aluminum parts.
Old Apr 2, 2007 | 09:21 PM
thesoundandthefury's Avatar
You go in different directions....for every grit...constantly.
Switch directions about every 3-5 seconds. It's tedious, but you'll actually work through each grit quicker and use up less paper than if you go in just one direction.
About the only thing sanding in a circle will accomplish over sanding in a straight line is to wear you out faster.
Old Apr 2, 2007 | 10:00 PM
Thanks i appreciate it.
