led turns
Old Apr 17, 2007 | 07:11 PM
MikeSomething's Avatar
Originally Posted by ZROCWS6
Ok. I found the flasherS. The turn signal one is to the right and the hazard one is to the left after you remove the lower dash cover under the steering column. I DID have the two prong flashers not the three prongs like I thought. I got them installed and the switchbacks look friggen sweet!
So wait...do I need to replace the hazards as well? Will the hazards not work if I only replace the turn signal flasher w/ the EL12 and not the hazards? This post is gettin confusing. I'm only swapping out the front blinkers w/ the switch backs...then later down the road, gonna put in LEDs in the rear blinkers.
Old Apr 17, 2007 | 10:04 PM
ZROCWS6's Avatar
Your doing what I just did. Swapping out for switchbacks.
From what I have personally done is that I found the flashers not knowing which was which. The first one I replaced turned out to be for the Hazards as the turn signals did not blink. After replacing the other flasher for the turn signals they blink. Now as far as replacing just the turn signal flasher and the hazards working I do not know. I would asume not. You could replace the turn signal flasher first and see if the hazards work and if they do return the other flasher.
Short: Yes you will need both flashers replaced for proper operation of both the hazards and the turn signals.
Hopefully this will help clear up any confusion.
Old Apr 18, 2007 | 07:32 AM
Transamin00's Avatar
took the bumper off, drilled a 1 inch hole and glued a new tower led in the stock housing. and jumped the wiring
turn signals have 3 wires
1 - high (amber led)
2 - low (running light/white led)
3 - ground
Old Apr 24, 2007 | 01:00 AM
2tone's Avatar
ls1s have 2 flashers... =o...I only found 1
Old Apr 24, 2007 | 11:51 AM
you only need to replace one, the turn signal one. the other one is for the hazzards
Old Apr 24, 2007 | 07:05 PM
ZROCWS6's Avatar
Yeah only one if you want JUST the turn signals to work properly.
Old Apr 24, 2007 | 07:23 PM
1meantransam's Avatar
transamin, do i have to do that same drilling noncence to keep my lights white when driving? because as of right now they are amber when driving? any simple remedies? i posted in here and i was removed and put to a section where NO ONE goes to post so i have had no help all day, i think you can help out though
Old Apr 24, 2007 | 07:35 PM
ZROCWS6's Avatar
From my experience they will light up white when the headlamps are turned on.
They are amber for the DRL and for your running lights.
With the running lights on they flash white.
With the headlamps on they are white and flash amber.
I am not really sure why he added another bulb. I have not had any problems with them looking washed out or anything like that. You can definatly tell when it switches between the two colors.
Old Apr 24, 2007 | 07:45 PM
ok and to put the flasher in do i have to unscrew anything or just pull off a peice of plastic and pop it in?
Old Apr 24, 2007 | 07:48 PM
ZROCWS6's Avatar
Nope. Just pull the old flasher out of the connector and plug the new one in. The connectors are red in color and are in a 90* shape. One on each side. Look for the connectors because you wont see the flasher itself as it is behind some plastic. The connectors should stick out the top and thats what you will see once you remove the lower dash cover.
Old Apr 24, 2007 | 07:52 PM
to remove that cover though am i going to need some screw drivers and stuff i havnt looked at it at all so i dont know
Old Apr 24, 2007 | 08:17 PM
  #32
EarlSS's Avatar
Is this how you would put the flashbacks in a camaro as well or is it different from a TA?
Old Apr 24, 2007 | 11:14 PM
  #33
they look good, not hard at all... i just need my other corner i only ordered one because i was short money but ordered yesterday, ordered my hid fogs today to
Old Apr 25, 2007 | 08:04 AM
  #34
LOHRTBT's Avatar
Well Damnit!! I dont want my switchbacks to be amber while driving..that is exactly why I hate them!! THey look like **** in amber! Damnit...NOw I need to find a different option than what I have on order. I want WHITE DRL's like I have now...but LED's. DAMNIT!!
Old Apr 25, 2007 | 08:52 AM
  #35
VIP1's Avatar
Copy & Paste Moderator
Get 3157 (white) LED replacements instead of switchbacks or 3157A (amber). The down side is that the turn signals will be white (which may be illegal in your state).
Old Apr 25, 2007 | 11:36 AM
  #36
yeah i want my turns to allllways be white, i hate having amber and white fogs well im driving looks kind of tacky you know? so should i just get basic white leds? which ones just the white towers?
Old Apr 25, 2007 | 11:39 PM
  #37
LOHRTBT's Avatar
right..but will I still have DRL and running lights at night and signals?? all white?? that is what I want. I have ran white signals for 4 years with no issues. Can you pm me a link to what you got that works like this?? I dont want to lose the functionality of the system and the last LED towers I got would not blink..but that was possibly due to the not having the EL12 flasher also haha.
Old Apr 26, 2007 | 12:11 AM
  #38
yeah flasher helps, go to autolumination.com for good leds
Old Apr 27, 2007 | 01:14 PM
  #39
xddesign26's Avatar
do you need a bunch of the EL12 flashers or just one does the trick for all your turns (front and back).
Old Apr 27, 2007 | 07:21 PM
  #40
you only need one. you dont really need to do the hazzard flasher, it works, it just works slower then normal. but there id not DOT reg that says how many times per minute they have to flash.
