How to hide engine bay wires..
Old Apr 13, 2007 | 10:42 AM
94blownz281's Avatar
Default How to hide engine bay wires..
I have the wire mod,latch mod done. fuel line mod in the works. but some of the engine pics i see here from guys that have large turbo setups don't have any harness or wires showing and it looks awesome. i don't know how they hide the injector wires for one.....
pics also..
Old Apr 13, 2007 | 03:42 PM
01badbird's Avatar
when you say latch mod are you talking hood latch ? And if so how?
Old Apr 13, 2007 | 04:29 PM
it was easy kinda disconnect the wire from the latch in front of the car,feed it back out of the front of the car. right where the hood support is that holds the hood there is kinda a hole there. drill or force the hole bigger and then remove the wheel well black plastic stuff. then the tricky part! feed the line down inside the wheel well and then just bolt the wheel well back up and feed the line moreless the same way it went. i can send you a picture if you want. i didn't remove the wheel or the whole well so thats why it was kinda a pain.
Old Apr 13, 2007 | 05:42 PM
MikeSomething's Avatar
I'd take it off. Don't make it hard on yourself.
Old Apr 15, 2007 | 07:37 AM
01badbird's Avatar
Thanks did wire mod on pass. side now going to do drivers side.Also thinking of getting rid of air system thanks again!
Old Apr 15, 2007 | 07:42 AM
Here is everything i removed, all the HVAC equipment,AIR,EGR,Fuel evap,wiper arms,fog lights,curise control,ABS unit,relocated hood latch,wire mod in the works,and fuel line relocation(LT1) in the works.
