Under hood bling
Old Apr 19, 2007 | 11:59 AM
LALT1's Avatar
I am going to do a write up and try to grab a few more pics of the fuel line set up. I also moved the PCM inside the car and a few other small things just to try and eliminate clutter. As soon as I get the write up done, i'll get it up.
Old Apr 19, 2007 | 12:00 PM
LALT1's Avatar
Originally Posted by GotV-8
That looks very nice, do you have anymore pics of your car? I love draglites.
I have tons of pics, I will get plenty this weekend tho with the new set up, some interior changes also. Also changed teh CETA mod to gloss as appossed to teh flat and a new tag.
Old Apr 19, 2007 | 01:50 PM
FredoCamaro's Avatar
Originally Posted by LALT1
Actually neither, those are the factory lines just rerouted. They worked out fine without spending a 100$ in fittings to do it.
Awesome! Did you have any trouble with the stock lines since they seem to be very stiff and not flexible?
Old Apr 19, 2007 | 08:40 PM
LALT1's Avatar
No problems at all, I will have the write up done this weekend I promise, trying to thrash and it get it finished for the rod run in pigeon forge this weekend.
Old Apr 19, 2007 | 11:22 PM
PipesTA's Avatar
I'm looking forward to your write-up.
Old Apr 20, 2007 | 12:03 AM
GotV-8's Avatar
Cant wait, im looking to get a set of draglites. I think you would like it a lot better if those side moldings were off there. I did when I took mine off. Just an idea....
Old Apr 20, 2007 | 07:02 AM
94blownz281's Avatar
you need to relocate your hood latch cable...
Old Apr 20, 2007 | 07:44 AM
themadspoon's Avatar
Wow beautifal car. Who makes those valve covers?
Old Apr 20, 2007 | 11:16 AM
TXws6's Avatar
wow... that thing means business! clean LT1!
Old Apr 30, 2007 | 08:07 AM
Sweet! What did you do with all the extra slack? Also, do you still run evap or are you only running 2 of the lines?
Thnx David
Old Apr 30, 2007 | 08:35 AM
he looped it in the fender. all i did was remove the connectors and cut the line the length i needed and put the connectors back into the lines. when you remove the evap you can delete that line all the way. just put a cap on the bottom of the line under the car.
