molding what is the best way to take off the molding on a 98 and will it take off the paint |
did it on my 2001. Used a heat gun to soften up the glue and started peeling it off by hand. Some people have used a piece of fishing sting to seperate the molding from the car, but i just did it by hand. When you get it off go back and heat up the left behind adhesive, or use something like Goo be gone. It did not mess up my paint at all and there was no color difference on the paint where the trim had been |
yea im getting ready to do it im just scared because unfortunately im not the original owner and im worried that there will be fading |
Originally Posted by fatdave did it on my 2001. Used a heat gun to soften up the glue and started peeling it off by hand. Some people have used a piece of fishing sting to seperate the molding from the car, but i just did it by hand. When you get it off go back and heat up the left behind adhesive, or use something like Goo be gone. It did not mess up my paint at all and there was no color difference on the paint where the trim had been |
used a hair dryer here. No fading, chipping or anything. took 20 mins and looks a ton better! |
I used fishing line to get the molding off then I just peeled the glue off while hitting it with the hair dryer... |
i just pulled it off.... the first side wasnt that easy, it left the sticky stuff on. i just had to work on it for a bit, and peel it off. on the other side, it all pulled off at once. |
WD-40 And fishing line. Done in 10 mins. :chug: |
lighter fluid gets off what adhesive is left. |
thanks for the in put |
here is how mine looks with out the molding[IMG]http://i160.photobucket.com/albums/t...5/100_0803.jpg[/IMG] |
© 2024 MH Sub I, LLC dba Internet Brands
