detailing a red car
what are some cheaper products out their that do a good job of restoring the color and eliminating some of these scratches?
thanks!
thanks!
I'd spent the money and find a good detailer, and then maintain it.
for a small area, I would recommend Meguiar's ScratchX .. if you are going to do the whole car, then ScratchX would not be a good choice.
For the whole car, grab someTropi-care TC-8 Swirl Cutter it will do a good job of light swirl removal by hand. If the pad Tropi-care recommends doesn't seem to be cutting enough, you can use a terry cloth pad, and get a little heavier cut out of it, but that may require you to go back over it with the pad, to get it looking perfect.
If you need to try and remove a little heavier swirling by hand.. then I would suggest Megiuar's #2 ..
Try the Tropi-care first.
