in the middle of hvac led install
Yeah the pre bent leaded LED's are supposed to go in. Mkae sure you have the orientation correct before you push them in all the way. You will most likely need to put a little force into getting them in securely. Same thing goes for the door LED's. I sent you a pm regarding all of the info that you will need and what links are helpful. A quick heads up, the headlamp switch will need to be soldered in.
Mike
