VHT Niteshade PROBLEM!!! NEED HELP ASAP!!
Old May 5, 2007 | 09:42 PM
my01ws6's Avatar
Default VHT Niteshade PROBLEM!!! NEED HELP ASAP!!
Ok well I painted my tailights and I painted all my turn signals and got the blackness where I wanted it and I went ahead and sprayed the clear on it....
The clear is like all white....its not transparent at all!! Im using acrylic enamel...is this what Im supposed to use or no?? Ive let it dry for like 10 hours now and a little of the white went away but its all blotchy now!!
How can I get rid of this??? Do I need to strip all the paint off?? If so what do I need to use?
I havent cleared the tails yet cause they are PERFECT!!! And dont want to mess them up like the turn signals did.
THANKS!!!!
Old May 5, 2007 | 09:47 PM
Z28LS1camaroguy's Avatar
wet sand it and see if that helps
Old May 5, 2007 | 10:08 PM
1SicV8's Avatar
x2......
if u need to, use laquer thinner and remove it. i didnt run into a problem with mine
Old May 5, 2007 | 10:26 PM
my01ws6's Avatar
what kind of clear did you guys use? and did you put it on thin or thick??
Old May 5, 2007 | 10:28 PM
Well it really depends on how you put it on, did you spray it on thick and fast coats or did you spary thin coats and let them sit for about 10-15 minutes then spray another coat building them slowly.
Old May 5, 2007 | 10:33 PM
my01ws6's Avatar
thick I always paint thick cause it makes it a solid coat.....but Ive only painted metal before....
Old May 5, 2007 | 10:40 PM
yeah that is not a good thing to do when doing VHT, just wetsanded it down alittle and then see if that helps.
Old May 5, 2007 | 10:43 PM
1SicV8's Avatar
you shouldnt paint anything thick!
light coats are the key!!! id wet sand if no change, start over with light coats...
i used duplicolor clear...
 Michael S. Palmer
Old May 5, 2007 | 10:44 PM
my01ws6's Avatar
I painted the VHT VERY VERY VERY thin almost like 9 coats before they were even black...I just did the clear thick....I dont have any sand paper right now...hmmmm Im down to 1 more can of VHT paint too....
Old May 5, 2007 | 10:48 PM
you shouldnt have to repaint the VHT, just the clear if it doesnt get any better, just wetsand it down and if it doesnt get better wet sand it some more, wipe it off and spray thin coats of clear.
Old May 5, 2007 | 11:01 PM
camar0guy's Avatar
you dont want to spray anythigng thick.
you want about 10 or so light coats, and then one heavy coat to get that pop shine
Old May 5, 2007 | 11:23 PM
my01ws6's Avatar
well its weird....I took the turn signals and wiped them on my shirt and the white stuff came off slowly....the longer I did it the more it came off....hmmmm
How should I clear the taillights? Maybe I should just get them professional cleared....
Old May 5, 2007 | 11:27 PM
camar0guy's Avatar
i put some nightshade on my GFs benz, 2 yrs ago with no clear, to this day it looks like i did it yesterday.
although it does have a few coats of Zaino on it
just another option to think about, but i did finish it off with one heavy coat for a glossy finish
Old May 5, 2007 | 11:37 PM
my01ws6's Avatar
im to afriad to put it on thick....i dont want to screw them up....I think I will just clear them or have them professionally cleared....I think they would look better professionally done.
Old May 6, 2007 | 10:29 AM
J2DSCO's Avatar
you should be able to sand it off. i've had some problems with my center brake light with doing stuff like that. the good news is, with some sanding, it will come off and you can do it again. maybe you should get a different type of clear coat. the bad news is, you're probably going to wear out your arm in the process.
Old Sep 30, 2007 | 11:16 PM
thosewhohatedmecreat's Avatar
1500 grit + water =
