Halo headlights?
Old May 9, 2007 | 09:22 AM
kyle91z28's Avatar
Default Halo headlights?
when you install the new headlights is it pretty straight forward? just screws and wire connections?
Old May 9, 2007 | 10:01 AM
WhosNXT's Avatar
You may have to change your headlight fluid also But seriously its really simple. If you can spell your name you can change your headlights.
Old May 9, 2007 | 10:23 AM
kyle91z28's Avatar
Well I figured it was easy as hell, but when I was looking at ebay about some one's I was thinking about buying it said "Professional Install Recommended," So i was thinkin wtf for headlights?
Old May 9, 2007 | 10:48 AM
g-ryde1's Avatar
It was an easy install jus ensure that you screw the alignment screws all the way in for an easier install all i did was get wid of the fog lights (I was on bulb no 3 on each) and tap the halo into the wire.
Install easy as pie
Old May 9, 2007 | 05:33 PM
one_wicked_element's Avatar
You may need to use your old lights' brackets. I installed mine, and have a bit of a gap. I'll be re-using my old lights so it looks better. The actual install is very easy
For some reason, I can't seem to get my damn halo's to light up. I know how to connect them, but I just can't seem to get a good connection.
Old May 10, 2007 | 12:15 AM
g-ryde1's Avatar
what wires did you use for the halos??
i used my fog light wires
Old May 10, 2007 | 01:11 AM
Kage's Avatar
Cool
Used mine with DT's/turn sign lamps.
