AC Delete
But, you will need to seal it up along the sides and also where the 2 heater hoses are. If not, all your air will blow out thru the firewall...
Where the heater hose's are is where it gets tricky and take awhile. There is going to be some huge gaps so you might have to put a little on, let it dry, then keep adding more till its filled in. You put alot on at one time and it just falls behind or in front if it.
that rubber nobby thing on the left, I just cut that flat. It looks exactly like mine when I had mine tore up..
It's one less thing to come off of the Engine, the Intake I have doesn't have provisions for that.
