HID Problem
Old May 16, 2007 | 04:29 PM
1meantransam's Avatar
Default HID Problem
i got the hid conversion from LEDgauges (fogs) and when i click unlock button my headlights pop up and only one fog will switch on (varies which one) and sometimes when i turn lights on only one lights up (also varies) sometimes i have to turn headlights fully on just for fogs to light up... any ideas?
Old May 16, 2007 | 05:10 PM
Havok2's Avatar
check the connections.
and i wouldnt have my fogs on, cus that i know, HID lights dont like to be turned on/off so quick so often. i assume everytime you lock/unlock your car the fogs light up and off, on and off....
Old May 16, 2007 | 05:12 PM
the car is locked at night then unlocked at at morning, then same process at noon when i go to work... assuming that both of the hids have whole different wiring boxes and what not and it switches back and forth i would think something other then connection because i never screwed with anything other then plugging these ones in
Old May 16, 2007 | 06:27 PM
SCRWS6
Guest
Posts: n/a
sounds like your gear is going bad....its when you use your remote? there isnt a grinding sound is there? Sorry, just wanted to see about the simple stuff....
Old May 16, 2007 | 07:40 PM
i havnt heard any noises as far as i can tell, its just one fog will turn on and it rotates between fogs, headlights are fine i dont care if they pop up or not, its the fogs... but im confused one why when lights are turned on only one will turn on untell i screw with it enough for them both to turn on
Old May 16, 2007 | 07:51 PM
SCRWS6
Guest
Posts: n/a
but your headlights gear might be going bad....only reason I`m asking on that one.
Old May 16, 2007 | 07:53 PM
naa headlights are fine, its the hids lol
Old May 16, 2007 | 07:58 PM
SCRWS6
Guest
Posts: n/a
fogs suck to get to.....loose wire maybe, bad connection somewhere
Old May 16, 2007 | 10:48 PM
but why the switch between which one would work?
Old May 17, 2007 | 05:29 PM
WonQuickZ28's Avatar
its just the fact that HIDs require more energy to fire up than conventional bulbs, my ZX6R does the same thing when I start it up with the high beam on, I just have to turn the switch to off and turn it back on again. theres really no fixing it.
Old May 17, 2007 | 06:10 PM
yeah that sounds about right but i sometimes have to click the switch 6-7 times lol
Old May 17, 2007 | 08:06 PM
ProjectCamaro's Avatar
I bought my HID kit from him as well. My connections weren't good at all so they were always shorting out. I had to redo all the connections myself to get them to stay on. It was a real pain but at least they work now.
Old May 17, 2007 | 10:22 PM
what did you do in terms of REDOING them all
Old May 17, 2007 | 11:14 PM
muddmanWS6's Avatar
yea i got fog lights from him and they are burning my fog light cover. anyboby have any idea on why??
Old May 18, 2007 | 12:21 AM
Havok2's Avatar
assume they are too long, meaning they are really close to the cover...
Old May 18, 2007 | 12:24 AM
VIP1's Avatar
Copy & Paste Moderator
Anything with an output greater than the stock 25watt fog light bulbs will melt the stock plastic fog light housings.
