how to adjust a door?
Old Apr 28, 2003 | 12:31 PM
last of the Z28's's Avatar
Default how to adjust a door?
i got a 2002 z. i also have a ground effects package. it doesnt seem to do it on the pass side but the bottom of the drivers side door scrappes just enough to leave hair line scrates in it. now can i raise the latches a 1/16 or will that screw up the hole geometry and screw up my hinges? or do i have to mess with the hinge side? the scratches seem to be more in the middle of the rocker so you can see it seems i can do either or both. looking for the easiest though. thanks
Old Apr 28, 2003 | 03:46 PM
JonSS's Avatar
Default Re: how to adjust a door?
I'd say, take it to the dealer.
Old Apr 28, 2003 | 03:57 PM
TransAm98's Avatar
Don't use the latch to fix it. You need to adjust the hinges first. Then check to make sure the latch is alinged right. It also helps to have an extra pair of hands.
