T-Handle Shift Knob (Hurst)
Old Aug 1, 2007 | 04:45 PM
HotWS6's Avatar
Default T-Handle Shift **** (Hurst)
Has anyone removed the stock T handle on 98-02 F bodies and replaces it with a Hurst t-bar shifter? I know the button mechanism on the side is there but didnt find any other t handles with that...any suggestions. I like the Hurst polished t handle.
Old Aug 1, 2007 | 04:48 PM
A-Dub's Avatar
Might try the transmission forum....
Old Aug 1, 2007 | 07:30 PM
VIP1's Avatar
Copy & Paste Moderator
Moving this to Appearance & Detailing.
Old Aug 1, 2007 | 08:30 PM
sdm1234's Avatar
I love mine. I wanted it to feel just like my '78.
Old Aug 2, 2007 | 02:33 AM
transambandit's Avatar
Hell yea do it, i love mine also. I searched and search around for a shift **** i would like, i also settled for paying the 100 bucks for a C6 **** but then i found this one and i love it.
Old Aug 2, 2007 | 07:51 AM
PontiacFan's Avatar
Come on people, ..., HotWS6 has an A4.
Read the details.
Old Aug 2, 2007 | 09:17 AM
Nine Ball's Avatar
LS1Tech Co-Founder
those are the worst design possible for a manual shifter, but work okay for automatics. Why are they crap for 6-speeds? Because to be a fast shifter when racing, your hand position has to change each time to get the most accurate/quick shift. That handle sucks for this.
Old Aug 2, 2007 | 10:54 AM
Snuffles's Avatar
I've attempted to.
To get an aftermarket **** to work with the stock shifter you need to pick up an adapter.
You'll see what I'm talking about in this link: http://www.01pewterz28.cz28.com/shifter.html
The Hurst and the traditional B&M T-handles will work with the adapter.
The B&M Hammer T-handle **** WILL NOT fit the adapter.
Believe me, I tried 4 different ***** from 4 different places, none fit. And the **** was advertised for the exact thread the adapter was.
The only T-handle I liked was the Hammer, ultimately I wound up picking up a MBA ****.
 Michael S. Palmer
Old Aug 2, 2007 | 11:15 AM
yes but its not like it takes you 6 hours to change your shift handle, if your going to race just swap it out, but for looks, this handle looks awesome.
Old Aug 2, 2007 | 12:39 PM
smg267's Avatar
I got the T-handle it looks bad ***!
Old Aug 2, 2007 | 04:27 PM
HotWS6's Avatar
So no one has put on a hurst or B&M t handle to replace the stock A4 T-handle? See my release button it on the side of the t-handle not the top, have a 2000 T/A WS6. I'll keep looking, someone has had to do it..
michaelg589's Avatar
x2
Old Aug 2, 2007 | 06:11 PM
67SS&99SS's Avatar
I don't know if the Trans Am shifter mechanism acts the same as a Camaro, since the Trans Am shift button is on the side of the handle, and the Camaro is in the center of it. However, if it did, you could possibly get the T-Handle to work with a fabricated adapter. My MBA **** came with an adapter that clamps to the shift cable of the trans and is threaded on the other end of the adapter for the shift ****. On my 99, this was a white plastic cable that came through the center of the shifter handle. You could then screw the hurst t-handle onto this adapter and use thin alignment shims to get it like you want it. The only real problem I see is making the adapater, since MBA is no longer in business. I'm sure a machine shop could set you up with one.
The T-handle in the M6 cars is a cool retro look, but as far as function, I prefer a different handle as a few others have said. For me, its the Pistol Grip.
Old Aug 2, 2007 | 08:13 PM
wannafbody's Avatar
I had a T handle on my 6 speed and the biggest downside was that in the hot sun it would burn my hands. I switeched to the black 6 speed Hurst ball.
Old Aug 2, 2007 | 08:47 PM
Randy WS6's Avatar
I have the Hurst Pistol Grip, I had the T handle but like the way the pistol grip fills,And when i bang second gear it fills like i could jerk the trans threw the floorboard
Old Aug 2, 2007 | 09:36 PM
Snuffles's Avatar
People have used T-handles to replace the stock ****, they used that adapter to do it.
You are not able to use any T-handle (that has to be threaded on) with the stock shifter without that an adapter.
Whether your button is on the side or on the top (like a Camaro) you will need that adapter.
Both of the shifters between f-bods are the same.
Old Aug 4, 2007 | 03:06 PM
HotWS6's Avatar
How does it disingage the shift from park to drive...etc.?
Old Aug 4, 2007 | 08:16 PM
67SS&99SS's Avatar
In my camaro, I push straight down on the **** to shift into reverse, drive, ect.....
Old Aug 4, 2007 | 10:47 PM
Snuffles's Avatar
By pushing down on the ****.
Instead of pushing your button in on the side of the stock ****, you push down on the aftermarket one.
Old Oct 21, 2007 | 12:36 AM
kebie05's Avatar
i am wanting a pistol grip shifter like in post 15. i have an a4 camaro, so what all will i need and where can i get it? i have no luck in searching for it. thanks
what kind of adaptor? any pics of one of those in a a4 camaro?
