Washing/waxing tips need
Old Oct 1, 2007 | 09:36 AM
Shackleford's Avatar
Default Washing/waxing tips need
I just bought a black '98 Trans Am that is immaculate. What washing and waxing steps should I take to keep it looking good? Keep in mind, I can't buy the expensive stuff. Thanks.
Old Oct 1, 2007 | 09:47 AM
chupr0kabra's Avatar
Where in Pearland are you?
-Mike
Old Oct 1, 2007 | 09:55 AM
jimmyducati's Avatar
for weekly washings i use turtlewax car wash, turtle wax liquid claybar and finish it with turtle wax liquid ice. the liquid ice is a pain to get off, works best if you do the wax on wax off mr meyge move with a damp cloth and a dry cloth, but once you get the haze buffed out is is very very smooth and deep looking.
Old Oct 1, 2007 | 10:05 AM
bluehawk2's Avatar
Use two sponges..............one for the dirty stuff(wheels fenders etc) and one for the hood and upper portions of the car. Just make sure to use a good clean sponge for washing. Also wash in a front to back motion...........if you do leave small scratches it will be hard to see them.
Old Oct 1, 2007 | 10:13 AM
ZaneO's Avatar
It doesn't necessarily take much money to maintain your finish properly.
Here's the way I recommend:
Supplies:
-car wash soap with high lubricity
-high quality sheepskin wash mitts
-foam gun (optional)
-2 buckets with grit guards for paint
-1 bucket and mitt for wheels
-high quality microfiber towels
-210+ mph electric leaf blower
-high quality sealant and/or wax
-quick detailer
Method:
-Wash wheels/tires/wells first to prevent spotting on paint and glass
-Don't use the same mitt or bucket for wheels that you use on your paint. The brake dust, etc. from your wheels will cause scratches and swirls in your paint.
-Using foam gun, cover vehicle in a thick layer of foam (optional)
-Use two buckets for washing paint. One with a soapy mixture, the other with plain water to rinse the mitt between panels.
-Never use circular motions. Always wash, dry, and wax using front to back and top to bottom motions.
-When vehicle is fully cleaned, allow a slow, steady stream of water to flow over each panel...sheeting the majority of the water off
-Use the leaf blower to blow all water from flat surfaces, mirrors, lights, etc.
-Remove any remaining water with a waffle weave drying towel and detail spray
*The less you touch the paint, the less chance of marring*
Keeping a good sealant and/or wax on the paint will assist in cleaning and reduce chances of marring.
