Fuel Rail Covers
Old Jun 14, 2003 | 09:11 PM
ApacheDrill's Avatar
Default Fuel Rail Covers
Is there a difference between fuel rail cover's for corvette's and camaro's? If so what is it...
Old Jun 14, 2003 | 09:47 PM
98sspullin'em's Avatar
Default Re: Fuel Rail Covers
yes ive been looking to get some but just slight mod's, need to cut some stuff for the egr and throttle cable i think but not to sure on the parts
Old Jun 14, 2003 | 11:10 PM
URPREY's Avatar
I used a set of stock C5 fuel rail covers on my car. They definitely needed to be trimmed, but I filled in the CORVETTE logo on them, and replaced it with Firehawk
Old Jun 15, 2003 | 12:13 AM
Ferocity02's Avatar
All fuel rail covers that you will see are probably first intented for use on the Corvette. Some people, like Parbreak, buy them and they modify them to fit on the Camaro, which is only some trimming. Parbreak will also paint some insanely cool graphics on the FRC's to fit your application. Or you can buy them yourself, fill in the "Corvette" on them, and paint them how you would like.
URPREY: What did you use to fill in the "Corvette" on the FRC's?
Old Jun 16, 2003 | 08:23 AM
How much trimming do you do Bill? Did you do it with a Dremmel? Nice to see you again.. Jim
Old Jun 16, 2003 | 10:15 AM
Ackattack1's Avatar
I filled the "corvette" in with bondo about 3 years ago. Now one of the letters is starting to pop out from the heating and cooling I'm sure.
I had to cut up the back part of them pretty good to get them to fit on my '01. I had them on my '99 and they didn't require nearly as much cutting. You can't see it though, cause it's back, under the cowl. I just used a dremel with a cut off tool.
