How to remove wipe arm?
Old Jun 17, 2003 | 07:29 AM
Larry's Avatar
Default How to remove wipe arm?
There is a nut that appears to hold the wiper arm on under a plastic piece. I removed the nut but the wiper still won't come off. What's the trick? Shouldn't it just pull off? I've used pliers but I'm afraid to get to rough.
Old Jun 17, 2003 | 09:47 AM
canadian z28's Avatar
Default Re: How to remove wipe arm?
There is an actual puller tool to buy. Looks a bit like a ball joint puller but, just like a ball joint, you can hit it with a hammer. USE MEDIUM TO LIGHT TAPS ONLY! We at the shop use hammers to take them off all the time. You have to put the nut on so it is flush with the stud and give it a few raps on top of the nut while pulling a bit on the arm as well. Feeling is the key here. Don't be wacking at it as if it were a ball joint!
Old Jun 17, 2003 | 10:34 AM
Larry's Avatar
Thanks!
I used a screwdriver, applied a little twist, tapped it with a hammer and it cam right off.
