vinyl decal removal?
Old Nov 11, 2007 | 01:20 PM
Twigs's Avatar
Default vinyl decal removal?
How do you remove a vinyl decal from the exterior... I am going to put a bird between my tail lights, but i dunno if I completely like the style of bird... is it easy? It is on the black part so i can sand it if that would help......
Old Nov 11, 2007 | 02:20 PM
The Guz's Avatar
Use some heat on the vinyl and peel off slowly. Once you remove the vinyl use an adhesive remover to remove any left over glue.
Old Nov 11, 2007 | 02:36 PM
Twigs's Avatar
ok thx... sounds easy enough.
Ill put some pics up of the new decals as soon as I take some =)
Old Nov 11, 2007 | 03:28 PM
fccs's Avatar
Yea really easy, use heat gun or even a hairdryer works fine. Just take your time and heat it up itll just peel right off then go over it with some detail spray and microfiber cloth and its gone.
Old Nov 11, 2007 | 05:55 PM
01ssreda4's Avatar
"oops" glue remover works great.
Old Nov 14, 2007 | 05:47 AM
green28's Avatar
used a heat gun to remove my stripes and would have been quick and easy had my stripes not been cracked.
