Retrofitting projectors, need some ideas/assistance
What I need to find is someway to cover up the projector so it's safe from the elements and looks nice to boot. Take a look at the pic below and maybe you guys know where I can find the part I need. I am referring to the clear plastic cover that is shaped to accomodate for the protrusion of the projector lense.
Any idea on where I could even find just this housing or this cover??
I was also thinking of trying to make a plexiglass version of the cover but this will be tricky to pull off and make it look nice.
Thanks.
-brian
Anyways, there are a million different ways to go about this. Depends on the money, time, and looks you want. Personally I'm not going to care about how it looks when it's done as long as it works because its a pop up. But I remember somebody posting a link up in here to a forum where someone did a write up on how to make your own custom lenses and ****. (if someone could repost that it would be greatly appreciated because i thought i added it to my favorites but i didn't). That would be a start and you could mess around with things like that, and it's fairly cheap to do.
My one idea I had was to use relatively thin piece of lexan and arc it in the shape you see above. Then make two well cut pieces of lexan in half moon shapes to cap off the sides. This would then be put on a sturdy plexiglass baseplate where it will be able to be squeezed in between where the trim ring holds the factory lights. I will gasket this so I hopefully won't get any debri or dust in these areas.
I have some used buckets I picked up so I can do this without needing to tear my car apart. I will most likely have to take a portion out of the back of the bucket. Once I get everything layed out, I can then installl it in the car. Hopefully I will get the look I'm looking for.
It's going to be interesting.
Any ideas?
If you are planning to use the stock Black plastic trim, you can either:
1: buy one of those e bay 4x6 headlights for about 25-30 bcks and use the lens out of it... just glue the lens from inside of that black plastic trim.
2: pick up sheet of lexan from Homedepot/lowes.. about 0.093" thick.. its like 5-10 bucks for 12x24... and just cut out square to cover the trim opening..
Now if the FX projector lens extends outside that stock plastic trim then:
1: buy sheet of lexan and a heat gun ($30 at homedepot). Find a round bottle (or anything like it) of about 4-5" diameter...with smooth surface... hold lexan sheet on to bottle (tangent).. using heatgun just start wrapping the lexan around it... you will get that dome shape... just cut out excess lexan and put it on..
2: make custom fiberglass trim that will extend more than stock (without hitting bumper when closing)... and use flat sheet of lexan in the front.
.-Brian
