Basic lighting Question, I'm a newb to lights
Old Dec 18, 2007 | 07:05 PM
purepwrta's Avatar
Default Basic lighting Question, I'm a newb to lights
I have a 96 T/A and everybody knows the headlights and fog lights have that yellowish tint to them when they are on. I want to eventually put HID's or something really sweet in but my pockets are low. But my question is: is there just a stock light bulb that i can switch out that illuminates more of the white or hyperwhite color rather than having to switch out the housing or anything else. I JUST want to switch out the bulbs if that is even possible.
thanks
tom
Old Dec 18, 2007 | 09:04 PM
Blackbirdws6's Avatar
you have sealed beam housings which means you can't just replace the filament inside of it. You need to purchase a whole new headlight if you want something new. Silverstars offer a little better light with better color but not much. If you want to convert to H4 lamps (does high and low beam, removable) and housings, then you have a wider selection of lamps and keep your housing.
I recommend Hella 165MM free-form housings with hella h4 lamps. I've done this myself and the lighting was improved dramatically. I then converted to a H4 HID hi/low kit which is ok but I am currently working on a bi-xenon projector setup.
-Brian
