Halo's Wiring Question.
Old Jan 4, 2008 | 01:42 AM
Ryan33187's Avatar
Default Halo's Wiring Question.
Alright so what I want to do is make it so my halos are my running lights ALL the time instead of the amber running lights. What I did was put the ground to the nut on either side of the air box, and have the brown wire from the AMBER running light to the power wire to the halo's. Here is the problem with the car running in daytime the amber lights are on, but when the headlights are on the ambers are off and the halos are on. If the car is not started and I turn the key to just the on position with car not started. The halos will light up and no ambers which is how I want it... Now why is it when the car is started that it is not like that? Any clues? The brown wire is not connected to the running lights at all only the ground is and the other wire I think it was blue I determend that had to deal with the turn signal because when I put voltmeter into the slot and clicked the turn signal I would get a reading otherwise I wouldn't.
Old Jan 4, 2008 | 08:34 AM
Havok2's Avatar
why not just ground the halos
connect both positives
and connect them a switch?
Old Jan 4, 2008 | 08:53 AM
ls1leadfoot's Avatar
halos arent very long lasting....i wired mine into my fog lights and chose when i turned them on and off.....i also have a bmw that the halos only lasted about 7-8 months.....plus you cant see them unless it's close to dusk ne how
good luck
Old Jan 4, 2008 | 11:05 AM
Ryan33187's Avatar
Mine are really bright they arn't led halo's they are CCFL tubes the leds are on the sides of the halos.
Old Jan 4, 2008 | 11:06 AM
VIP1's Avatar
Copy & Paste Moderator
If the Camaro's DRLs are wired like the Firebird....
- The bulb is dual filament.
- The bright filament is the DRL during the day.
- The dim filament is the DRL at night.
- The bright filament is also used for signals.
That functionality is controlled by a small box behind the radio.
If you want the DRL on all the time instead of the amber DRL, you might be better off wiring them into an ignition-switched circuit for power and defeat the DRL.
Old Jan 5, 2008 | 02:03 PM
squirrelishere's Avatar
I've had my halos for over a year and half now. They still haven't gone out and my Z is my DD as well. I just wired them to the the side markers that are always on. Havne't had issues yet.....
Old Jan 7, 2008 | 07:37 AM
Ryan33187's Avatar
Anyone have any ideas how to do it threw the DRL's?? It works perfect at night, but during the day it does not... It is really odd.
Old Jan 7, 2008 | 11:15 AM
VIP1's Avatar
Check out my previous post as to why that happens.
I don't know why they designed it that way.
Old Jan 7, 2008 | 11:26 AM
Is DRL an option on Camaros? Cuz during the day, my headlights are off, just the side markers are on. Headlights turn on automatically at night though.
Old Jan 7, 2008 | 11:37 AM
VIP1's Avatar
If I remember correctly, the front/side amber signals/markers on the Camaro are the DRL (the amber front signal on the Firebird is also the DRL).
The headlights turning on at night is the auto-light feature which the USA Firebird doesn't have but the Canada Firebird does.
