Appearance Overhaul Questions ?
Old Jan 6, 2008 | 04:52 PM
multiplicityZ's Avatar
Default Appearance Overhaul Questions ?
When you guys that go through the yearly, or even more often, full detail process does it generally matter what kind of weather that you do it in? the reason i ask is because my black SS is in dire need of some attention to the swirls in the paint, and my shop that i built just before winter still doesn't have heat and i want to do the full detail, clay bar, PC, everything.
just wondering if the cold weather here will matter too much which is ~ 35 degrees at the most.
thanks for your help
Old Jan 6, 2008 | 05:09 PM
WS6Jim's Avatar
It makes a difference. If its too cold then the wax won't spread evenly and won't come off or go on as easily. I would really wait.
