frc how to?
Old Jul 10, 2003 | 09:31 PM
98trans am's Avatar
Default frc how to?
i just got my fuel rail covers in but i can't find anything on how to trim them. can someone help me?thanks
Old Jul 10, 2003 | 10:21 PM
Ferocity02's Avatar
Default Re: frc how to?
I will write up a modify and install guide if you want it. I found pics of others' FRC's and copied the cuts. Then I trimmed a little more to make them fit perfectly. They fit so well I can put each on on in about 10 seconds.
Look through this forum (Appearence) and find a thread called "Post Pics of your FRC's!" Should help you out a lot.
Old Jul 11, 2003 | 11:14 AM
98SilverZ's Avatar
Or you could try this website. This is the one I'm using. Good luck.http://www.sysadminzone.com/ta/z06cvrs/
Old Jul 11, 2003 | 11:29 PM
01redws6ta's Avatar
I tried following pictures and procedures from other sites and finally just tossed them aside and trial fitted them a bunch of times as I cut to make them fit. This worked best because the pictures I was following were for a earlier model (AIR system a little different) and the cuts weren't right. Also, I'm picky and didn't want things rubbing on them. I took about 1.5 hours or so to cut and fit each cover. They turned out nice though. I did the Z06 covers to match my red WS6 TA.
Old Jul 15, 2003 | 11:27 AM
98trans am's Avatar
thanks guys
