headlight adjustment
One above and one to the side.
The one above is for up/down adjustment.
The one to the side is for left/right adjustment.
They are visible/accessible through the front of the shroud.
The shroud has a notch above and to the side of each bulb.
The screw has a Torx head.
If I remember correctly, the size is T15.
If you remove the headlight, you'll have to recheck aim when you reinstall it.
