Battery Relocation
Old Feb 14, 2008 | 04:56 PM
Italiankid77's Avatar
Default Battery Relocation
If you have done it,were did you buy the kit from let me know thanks.
Old Feb 14, 2008 | 06:07 PM
Rai's Avatar
Rai
i would also like to know
and also -- what are the advantages of a rear mount battery
and do you just run the wire as you would on a amp set up to the rear for the pos. and run the neg. to a ground
thanks
Old Feb 14, 2008 | 06:46 PM
H21surfer's Avatar
I did it... I just bought a cheap battery box, and ran #2 welding cable from the battery back up to the fuse box. Battery is now in the spare tire area. Also, you will need to ground it, and I did it at several locations around the car.
Advantages... Make room for some goodies .
Old Feb 14, 2008 | 10:38 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
You might find a lot more on this if you check out the Drag Racing Tech section
Old Feb 15, 2008 | 02:45 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
Moving the battery to the rear near PS rear tire does indeed make room for much crap under the hood in the area where the battery was, but, the true reason to do this is to remove the weight of the battery from the front and place over PS rear tire to improve weight transfer of car when launching at strip.
Old Feb 15, 2008 | 07:18 AM
Mike@HSW's Avatar
summit and jegs both carry a battery relocation kit. Depending on the track you may need to switch to a dry cell battery. If you dont go that way you have to get a sealed battery box with a vapor tube that leads to the outside of the vehicle. Similar to a blowdown tube for a nitrous bottle. As stated above the main reason for doing this in drag racing is weight distribution for the front to the rear which will help with traction. Also gives you room up front for things like a standalone fuel cell. If you dont need the space for something like that and you dont care about drag racing i would just dress up the battery with Specialized Stainless battery cover. its cheaper then relocating and looks great
Old Feb 15, 2008 | 11:40 AM
Reject's Avatar
i built mine with no rules so it basically isnt legal on any track. i bought the one from summit and could not figure out the instructions cuss it looked like black inc was spilt all over the paper. i just used the cable and the end connecter to make my own kit. i wil buy a dry cell later on or build a box to go over this one when i am done building my hotparts. let me lok for pix
