ultimate detailer machine
thanks
good luck! The UDM is very closely aligned with the PC in many respects. The UDM does have a little smoother and tighter rotation at increased speeds compared to the PC. It claims to have about 20% more power with its top speed at about 7200 OPM vs. 6000 on the PC.
The only way to damage the paint is to drop the machine on the car. There are a number of variables to give you results on the paint. Pads, products, machine speed and rate of movement are just some of them. Don't be afraid to start with a less aggressive combination such as the white pad and Swirl Cutter to get a feel for the machine.
Remember there are plenty of us here with experience who can guide you while you are learning for yourself. Just ask. The only foolish questions are the ones that aren't asked or asked after it's too late for correction.
. Camaro's typically have a pretty hard clear coat so it takes some work getting those swirls out.
