Door Jam code
Old Mar 4, 2008 | 06:34 AM
SSquid's Avatar
Default Door Jam code
What door jam code should I look for to see if its a true SS? 2000 is the year if that matters? Also looks like the car was jacked up from the DO NOT JACK PLATE... so it looks to have pushed the bottom of the fender out a smidge.... is that fixable?
Old Mar 4, 2008 | 06:39 AM
Iron Head's Avatar
WU8,Yes.
Old Mar 4, 2008 | 06:49 AM
SSquid's Avatar
Thanks, gettin ready to buy a 00 SS with 28k for 14000 had those concerns... how do you fix it? body shop or can I do it myself?
Old Mar 4, 2008 | 06:57 AM
99zee's Avatar
You can usually fix it yourself. Take the two bolts out and bend the flange back straight. Then reinstall the bolts. Hopefully they didn't crush it flat. Happens all the time.
Old Mar 4, 2008 | 06:58 AM
Iron Head's Avatar
Info for fix.
https://ls1tech.com/forums/showthrea...ix#post4526946
