gauge power source
Old Mar 19, 2008 | 07:23 PM
therobman's Avatar
Default gauge power source
i have autometer gauges and i have the light hooked up with my radio its ok but it only goes off when i open the door is there a way to wire it up so it goes off just when i turn the key off?
Old Mar 19, 2008 | 07:55 PM
enos44's Avatar
on the autometer instruction guide it should have showed you i wired mine so it would stay on all the time got my power from the fuse panel on the drivers side
Old Mar 19, 2008 | 07:59 PM
WhiteStripes's Avatar
You wired it to a source that runs off the auxiliary power, so technically it'll time out and go off when your aux power shuts off. I don't know where mine is wired to as it was pre-wired, but if you are just talking about illumination, then you want to hook it up to somewhere that the light **** for the car switches.
Old Mar 19, 2008 | 08:16 PM
therobman's Avatar
howd you wire it in the fuse pannel i assume the illumination one went on the dimmer fuse but what about the 12+ power
Old Mar 19, 2008 | 08:34 PM
blackbyrd's Avatar
pull the gauge cluster off and hook it up to the pink wire in the guage connector or you can ty it into the pink wire under the steering colum this is the switched ignition wire.
Old Mar 19, 2008 | 09:47 PM
transam5.7lt1's Avatar
^^^ We got a winner!
