painted underside of car
Old Mar 23, 2008 | 12:54 PM
barnat's Avatar
Default painted underside of car
Has anyone used anything other then base/ clear to do the underside of there rides? My buddy wanted to do my 35th LE with some type of colored hard bed liner type stuff !!Just wondered if any of you have tryed or have used this type of system? looking for somthing that will hold up against the rocks and stuff and just hose down every so often ?If so any pics ??PLEASE LOL!!Thanks BARNAT!!
Old Mar 24, 2008 | 12:37 AM
blindxeyed's Avatar
I've heard great things about POR-15
Old Mar 24, 2008 | 12:39 AM
venomhp's Avatar
I use por 15 silver on the body parts and the traditional black for everything else
Old Mar 24, 2008 | 06:30 AM
sleepinghawk's Avatar
I did the underside of my Hawk with Herculiner. The stuff for the back of pick-up truck beds. Works great. I did it because the oem undercoat was cracking. I put it everywhere the undercoat was. I am very impressed with it. **** is tuff, dries really quick. I have used all kinds of spray undercoat, I won't go back to that stuff.
Old Mar 24, 2008 | 08:24 AM
Brian2006's Avatar
How did you spray it upside down? How did that turn out for you?
Old Mar 24, 2008 | 09:09 AM
Hawk108's Avatar
How much does that stuff weigh?
Old Mar 24, 2008 | 10:29 AM
ckyconan2003's Avatar
por-15 is amazing, you can bruch it on and it looks smooth as skin!
Old Mar 24, 2008 | 10:32 AM
Luna's Avatar
I just started using the eastwood alternative to POR-15 "Rust Encapsulator" it seems to work pretty well.
I'll post up some pics when its all done.
 Michael S. Palmer
Old Mar 24, 2008 | 12:53 PM
DUhulk78's Avatar
Herculiner is a roll-on liner. It comes with the roller attachment and all the necessary stuff. It's good stuff too, and it's not very heavy, probably not any more than POR-15 is. I did a swingarm off of my ATV with herculiner, and it held up through everything i've put it through (and i ride hard).
Old Mar 24, 2008 | 02:53 PM
SIC LSX's Avatar
my car cam with factory undercoating
Old Mar 24, 2008 | 04:42 PM
tbird31's Avatar
I cleaned the underside of my car then used a Duplicolor Truck bedliner coating. Looks great. My friends use it and it holds up well.
Old Mar 24, 2008 | 10:11 PM
barnat's Avatar
Ive used the POR stuff on my exhaust like the one guy said, brush it on and it flows as it dries LOL! It does too! I never thought about it for the flooring That might be what ill use. I gotta talk to the paint supplier about it though, He may recomend that herculies stuff? Well, thanks guys ! I gotta do somthing here, ****!!The underside of my LE looks like it barrely got an overspray thats how little it got hit at GM when they did mine HUM!!you guys got my brain worken now !!LOL!!Thanks guys Any pics would be great if any of you got any?of your under sidesBitches included
Old Mar 24, 2008 | 10:13 PM
barnat's Avatar
Default Heat
dont forgett guys!!Its gotta hold up to the exhaust heat too!!Sitting at a red light on a 95 Deg day doesnt help much under there!
Old Mar 25, 2008 | 08:09 PM
barnat's Avatar
does it come in red????The por doesnt from what my local paint supplier says!!
Old Mar 25, 2008 | 08:15 PM
barnat's Avatar
Default no por in RED??
My local paint supplier told me today that the por doesnt come in red!!Which is what I need What to do now ?????Any ideas guys? I was even thinking of redoing the underside in the base RED like it was from GM with no clear but in a complete cover,Not a half *** overspray type paint job!like GM did on my LE!LOL!!!Maybe because they were the last, and GM was like push em threw anyways LOL!!
Old Mar 26, 2008 | 08:27 AM
Luna's Avatar
The eastwood stuff only comes in matte black and I think clear. I dont think it would look bad if you just did the underside black. regardless of the color of the car
Old Mar 26, 2008 | 06:44 PM
Sorry man, I died for a few days. I did it all with a 2 inch cheap paint brush. I didn't use the roller that came with it. I drove up on my ramps, and jacked the front the same and pulled all wheels off and I was done in no time. I used the stuff at work so I knew what to expect.
Old Mar 26, 2008 | 06:46 PM
No idea. But it seems thicker than paint, but it will run. Advance auto, Autozone, even Walmart I believe has it.
Old Mar 26, 2008 | 07:48 PM
NIGHTMAREWS.6's Avatar
Here is POR in gloss on my rear axle, after a good sanding.
Not the best shot, but you get the idea.
Old Mar 27, 2008 | 09:11 PM
michaelg589's Avatar
^^^ Thas purty ^^^
