hot to install clear corner lenses???
Old Jul 27, 2003 | 05:31 PM
NaSSty99's Avatar
Default hot to install clear corner lenses???
hi,
i have some clear corners that i tried to install this weekend,
the problem is that i couldn't remove the factory corners lenses from the front bumper, i removed all bolts and screws holding it, but i don't know if it should come out from the front of the bumper or from the inside through the hood.
plz let me know what's the easiest way to do it?
thanks,
Old Jul 27, 2003 | 05:39 PM
RJF's Avatar
RJF
Default Re: hot to install clear corner lenses???
they come out from behind mine where all chipped and cracked so i was not really carefully and just got them at the right angle and pulled and they came right out without breaking.u might want to lay a brand a silicone where the clear corners are glued together my just filled full of water and the led bulbs just blew
Old Jul 27, 2003 | 06:55 PM
YIKESS's Avatar
The easiest way to install them is, remove the headlights, it's 1 10mm screw that holds them in. After you remove that, unplug the headlights, there are 2 tabs on the back of the lights, just slide the whole headlights assembly to the center and take it out. Take your time with this, it can get tricky. Then you have total access to the coners.
Old Jul 28, 2003 | 12:08 AM
BlackEcho's Avatar
it is kinda trick to get the stock lenses out. I just did it yesterday. What i did is like YIKESS said i took hte headlight out and pushed the factory corners a little inside and sorta forced the tip of the corners out first.it takes a while but you will get it out.
Old Jul 28, 2003 | 02:33 AM
NaSSty99's Avatar
thank you all,
i just did it today, it took some time but it's all good now,
i'll try to get some pics sometime later,
thanks,
Abdulla
Old Jul 28, 2003 | 06:49 AM
DARK AGE 53's Avatar
https://ls1tech.com/threads/showflat...rue#Post514861
