The BEST Headlights period....
(in no particular order)
Acura TSX
Honda S2000
FX35/FX45
Porsche/Murano
LS430/SC430
You might be able to get one of those Camaro projector headlight housings from ebay and replace its projectors with one of the above, or you can retrofit one of the above projectors into your stock housings.
Check out www<dot>hidplanet<dot>com/forums/ for plenty more info on that.
You can also check out the Lighting FAQ here on LS1Tech. There is a link in there where someone retrofitted Hella 90mm H9 projectors into the stock Camaro headlight housings.
Lighting FAQ: https://ls1tech.com/forums/appearance-detailing/710357-lighting-faq.html
Although it is an improvement (and I have the same projectors in my Formula), the projectors I listed above are better.
Ill be starting on this project in the next 6 months.
