NEED HELP! white paint and clear coat
Old Apr 10, 2008 | 07:17 AM
AzzBustin30th's Avatar
Default NEED HELP! white paint and clear coat
im cleaning up my engine bay on my trans am. i got it all painted up white yesterday and im waiting for it to be good and dry. my friend said he heard that the clear coat in a rattle can when sprayed over white makes it have a yellow tint to it. anyone have direct experience with this. i would hate to ruin my 30th. it looks so rad as it sits now but some clear would really set it off.
Old Apr 10, 2008 | 07:42 AM
z28voodoo's Avatar
yeah most clearcoat that is... not the best quality.. will turn it a yellow tint, and white will def. show up. if you could i would get some House of Kolor or PPG clear coat, or just your local auto/paint store brand.. just ask the guy if it will turn yellow over time lol. if you have access to a spray gun or know someone that is decent with one. it will look a ton better and wont turn yellow.
but then again if its just the engine bay it may not be *too* noticeable.
Old Apr 10, 2008 | 07:45 AM
9000th01ss's Avatar
It usually does, there are very few brands out there that won't.
For $150 to $200 you could get 8oz PPG Base(16oz sprayable) and a quart of PPG speed clear, and primer(with all the reducers and hardeners) . Then get a Prevail refillable spray bottle $5 at Napa.
Costs more of course but your good job will last several more years.
Old Apr 10, 2008 | 09:43 AM
DUhulk78's Avatar
I've had good luck with the duplicolor clear rattlecan surprisingly. It's not too bad far as durability. I painted a front panel with white and clear rattlecans on my old grand prix a while ago just cause i'm cheap, but i wetsanded it and everything and it turned out pretty good. It's pretty cheap too. My advice is though to try some on a piece of plastic or something, just paint white then try some clears. If you like the turnout then go for it.
Old Apr 10, 2008 | 11:33 AM
9000th01ss's Avatar
Problem is age will yellow it, it will go on clear. But in a few years it will yellow and you'll either live with it or find yourself doing it over.
Old Apr 10, 2008 | 05:11 PM
thanks for the input. i really appreciate it.
