Wire Mod Help Please (ASAP)!!
Old Apr 15, 2008 | 03:27 PM
HOSS's Avatar
Default Wire Mod Help Please (ASAP)!!
Finally got around to doing this. I have removed the 7 and 10 mm bolts, I have left one phillips head screw that is acting like a push in rivet type deal, and then two other rivet type things just behind the wheel on the painted fender part. I can't for the life of me, get these things out, and I don't want to mess up the way the fender looks. Any suggestions??
Old Apr 15, 2008 | 03:31 PM
ramsoccer11's Avatar
pop out the center section of it w/ a flat head and the remaining part just pulls out
Old Apr 15, 2008 | 03:42 PM
HOSS's Avatar
it wasn't those type of push pin things. i got pissed and cut the damn things. have to go the parts store and get some new ones..lol. Thanks for the reply though
Old Apr 15, 2008 | 03:55 PM
ROCNDAV's Avatar
What I usually do is unscrew them while putting a thin little flat screw driver under the edge of the screw head. you kind of have to pry it up a little bit until the threads catch then it will unscrew by turning the phillips head counter clockwise.
