Rear tie downs removable?
Old Apr 24, 2008 | 04:16 AM
ls1owner4life's Avatar
Default Rear tie downs removable?
Searched but no definite answer. The rear tie downs on 00' + rear decks are they captured by a nut underneath or can I un-install and re-install them in the future. I built a sub box and they are in the way. Thanks.
Old Apr 24, 2008 | 10:21 AM
VIP1's Avatar
Copy & Paste Moderator
The rear tie downs can be removed and re-installed easily. No funny business. You just need the right size Torx bit (I forget the size).
Old Apr 24, 2008 | 08:39 PM
GETGONE's Avatar
They have a raised piece with a threaded insert that's welded to the floor. You can remove the tie downs but you will still have a small hump where each one is. If you want it truly flat, you'd need to take a cutoff wheel and cut the bracket off.
