Lightbulb issues (Right section?)
Old Apr 27, 2008 | 03:50 PM
Brickyard's Avatar
Default Lightbulb issues (Right section?)
I think this is the right section, it doesn't seem like "general maintenance" to me.
I have a dead sidemarker socket, so I thought. So I replace the bulb with a LED and it still didn't work... okay dead socket. I put another extra bulb I had in there and voila it works. But here in lies my problem, I have clear sidemarkers, so I have to have a red bulb in there. I have tried two bulbs, and two led bulbs, and the only one that works is the regular white bulb? Any ideas on this one?
Second problem, when changing my dome light bulb it lit up for a second, and then all of a sudden I have no power locks. The key fob doesn't work, and the buttons on the door don't work. I figure it's a fuse, and I found a 25amp fuse that was blown, but why would changing a lightbulb short out the whole system?
Old Apr 27, 2008 | 05:15 PM
MadIceV8's Avatar
Customizing Director
I would check the blubs that don't work in another socket or take a volt meter and do a test to see if voltage is even flowing through the bulbs (continuity test I believe).
You can also add some dialectic grease to help the connection.
Old Apr 27, 2008 | 11:46 PM
Brian2006's Avatar
Also, turn the LED bulbs 180 degrees, they are polarized so you the polarities have to match up.
Old Apr 28, 2008 | 12:09 AM
VIP1's Avatar
Copy & Paste Moderator
Also, if you replace the turn signals with LEDs, you need to replace the flasher with an electronic flasher (ex: Tridon EL-12, $8 at AutoZone). LEDs don't draw enough current for the stock thermal flashers to work.
Old Apr 28, 2008 | 01:54 AM
Brickyard's Avatar
I wouldn't think that the sidemarkers would need a flasher though? I have tried flipping them 180 degrees, no dice there. I will try the dialectic grease, I think I have some around here somewhere, if not I will pick some up tomorrow.
Old Apr 28, 2008 | 09:04 AM
Danny2tek's Avatar
I would first check the socket with a VOM (volt meter)
Old Apr 28, 2008 | 09:53 PM
VIP1's Avatar
Correct. I missed that part.
