Berger Panel Questions!!
Old Apr 28, 2008 | 02:08 PM
Assassin66's Avatar
Question Berger Panel Questions!!
alright...so i'll probably be doing the berger panel on my car either today or tomorrow...i dont know if this is a stupid question but here it goes: do i have to sand the factory paint off or can i just spray over it and not worry about it chipping off?
Also any suggestions are welcomed...btw what kind of paint are you guys using; flat, semi-gloss or glossy and wat brand?? I have read some people that have done it do not use clearcoat on it, will it chip easily if you dont? Thanks fellas
Old Apr 28, 2008 | 02:12 PM
Unstang's Avatar
You don't need to sand off the factory paint, just use a red scotchbrite pad & dull it down really good. Then clean it, prime it & paint it. (Probably don't need to prime it.)
I think semi gloss looks best...The last one I did, I used John Deere paint & it sprayed out the best of any rattle can I've ever used.
Old Apr 28, 2008 | 03:50 PM
95GreenZ28's Avatar
I used satin but it does have some good shine to it. Like Unstang said just scotch brite it, clean it off, and spray
Old Apr 28, 2008 | 05:10 PM
Assassin66's Avatar
some people have suggested wet sanding the factory paint off with either 400 or 800 grit paper...how much more work would it be to go this route and is it even worth it?
Old Apr 28, 2008 | 05:15 PM
Unstang's Avatar
Not worth it, no reason for it.
Old Apr 28, 2008 | 05:19 PM
Ntimid8r7's Avatar
I did the 800 wetsand on mine. It can be done in about 30 minutes depending on how aggressive you are. I took my time and got all the little nooks. I didnt take it all the way to the primer but scuffed it up really good and used a clear adhesion primer and used about 7 coats of semi gloss black. All rattle canned. Then applied the stainless. I did it over a couple of days. Let it dry good before you do anything.
Old Apr 28, 2008 | 05:56 PM
Assassin66's Avatar
That came out awesome Ntimid8r7...did you throw in any clear coat on it?
Old Apr 28, 2008 | 06:10 PM
Ntimid8r7's Avatar
nope. just left it the way it is. it should be fine i hope and if not i only have $12 in the paint job. I can reshoot it.
Old Apr 28, 2008 | 08:59 PM
Z28LS1camaroguy's Avatar
make sure you get in the letters really good, otherwise it will start to chip.
Old Apr 28, 2008 | 09:05 PM
mycamaroSS's Avatar
i would say take the time to do it right, atleast wetsand it with 800 till there is no color left. No need to do a halfass job and end up having to worry about peeling in a year or 2
Old Apr 29, 2008 | 01:14 AM
Badguy7's Avatar
Ok, so you guy's are just painting the stock one??? I want to get a Berger Panel, but maybe i will decide on painting the stock panel.
Old Apr 29, 2008 | 12:20 PM
Ntimid8r7's Avatar
I kept the LPM one for my SS and bought one from the bone yard for it for $25 but I used the one on the Z. Pretty much just depends on what you wanna do.
Old Apr 29, 2008 | 12:43 PM
Badguy7's Avatar
Oh ok, yeaa think im just gonna get another 1. That way if i ever change my mind or get tired of the look, i can swap them out and get the stock appearance again.
Old Apr 29, 2008 | 01:16 PM
thats what i did, bought another one from a member on here for like 50 bucks. good thing i had my backup b/c im reapainting mine again lol.
