Wet Sanded...Now What?
Old Apr 30, 2008 | 07:57 PM
MetallicaMatt's Avatar
Default Wet Sanded...Now What?
Hey guys,
next week when I get my new hood put on, i'm having the entire car wet sanded with some 2000 grit
what should I do once I get it back? I want to make the car look that good for as long as possible
I've always been a meguiers guy, but since i'm sort of starting over with the paint job...what should I do??
Old Apr 30, 2008 | 07:58 PM
LT1-DAN's Avatar
You have to buff it out.
Old Apr 30, 2008 | 08:03 PM
Slvr00Bird's Avatar
Then a hard wax.. last longer then the liquid *****..
Then get in a routine of doing it OFTEN...
Old Apr 30, 2008 | 08:11 PM
Richie Carbone's Avatar
BADA BING BADA BOOM!!!!!!
What ever you do, don't wax the freshly painted hood for 60 days. The solvents in the paint and clear need to evaporate, so if you wax it too soon the wax will trap those solvents in and cause problems.
You can wash wash it right away, but don't wax it.
Old Apr 30, 2008 | 08:13 PM
VENOMIZED03's Avatar
After 2000 I would use some 3000 if it were me.
Old Apr 30, 2008 | 08:17 PM
Slvr00Bird's Avatar
Yea, thought that was understood.. but good to point that out incase not..
Old Apr 30, 2008 | 09:17 PM
SS4Matt's Avatar
indeed. 3000 trizac from 3M on a DA, then get out the wool pad and some decent compound (i use wizards finish cut myself) and then have at it. then after the wool step, take a foam pad of some sort and do it all over again to get your wheel marks out. then wax!
Old May 2, 2008 | 01:37 PM
I know I can't wax the hood
what about a polish?
Just trying to think of how to keep the car looking good. Or just give it a good cleaning/waxing after 60 days
 Michael S. Palmer
Old May 2, 2008 | 04:21 PM
ArcticZ28's Avatar
Wait, only the hood is being repainted, but the rest of the car is getting 2000 wet sanded? Then they are gonna return it to you without buffing? You'll need to follow SS4's instructions for that, then. As for the hood, just keep it clean for a month or two, then clay bar it and put your fave sealant/wax on it.
Old May 2, 2008 | 05:51 PM
mcalus's Avatar
I am hoping this isn't stock clear they are sanding? If so you better hope they dont burn threw any where.
Old May 2, 2008 | 08:20 PM
Red99TA's Avatar
Not the best idea to wetsand a stock paintjob. They don't use a lot of clear so it's easy to sand through it to the base. If it's too late then just get a good polishing compound like 3M's Perfect-It II or something like Menzerna Intensive polish and final polish using a DA polisher. There's no real need to go to 3000 grit although it will make the polishing step faster.
Old May 2, 2008 | 08:26 PM
ArcticZ28's Avatar
I don't mean to direct this at anyone in particular, but a lot of people jump to wetsanding without really understanding what it does. Clear coat is there not only for protection from scratches, but also for UV protection. Paint quickly fades in the sun without protection, and the more clearcoat removed, the more UV that gets through. Wet sanding problem spots is one thing, but wet sanding an entire car when it was not properly prepped for it (more clear intentionally sprayed in preparation for wet sanding) could certainly lead to premature paint degradation.
Old May 2, 2008 | 08:30 PM
wannafbody's Avatar
Get some wool pads and 3m 3000 rubbing compound. Follow with some Menzerna Internal polish and finish with Menzerna final Polish 2 on a black foam pad.
Old May 3, 2008 | 10:32 PM
The wet sand was his recommendation to remove the factory orange peel. He thought just buffing alone wouldn't be enough (black car)
