Paint billet grille black?
Old May 5, 2008 | 09:44 PM
hallass's Avatar
if you just paint it black, sand it and primer it so that the paint sticks well. i painted mine first and ended up with a bunch of tiny chips in it. my solution was a can of spray on bedliner coating. it has a little texture to it, but i can probably drag it down the road behind the car and it will still look good
Old May 5, 2008 | 09:45 PM
phantomzer0's Avatar
I personally like it better the way it is. As long as the area behind it is painted back then the grill will look great! Keep it polished!!
Old May 5, 2008 | 10:16 PM
slikrider20's Avatar
So basically i just need to sand it, primer it then paint it. What kind of paint should i use? I've never really done any painting work before
Old May 5, 2008 | 10:33 PM
hallass's Avatar
use some type of durable paint. maybe duplicolor wheel paint would be good since it's pretty tough if you just want to use paint. like i said above, i used the duplicolor truck bed coating and it came out great. regular paint will probably chip over time, but this stuff is hardcore so you won't have to worry about it again. it's not glossy, but kind of a matte finish with a texture to it, which looks great IMO.
this isn't a closeup, but it'll give you an idea.
