Projectors Finally Installed...
Old Jun 7, 2008 | 10:05 AM
bigtymer386's Avatar
should have saved the money and fixed that front bumper IMO.
Old Jun 10, 2008 | 08:06 AM
HibachiZ28's Avatar
The fogs don't even work properly. They are coming out soon to be replaced by round mini projectors most likely.
Why put priority on looks over safety? I drive extremely dark back country roads almost daily. No street lights and not many houses. I needed these lights more than anything else on the car at the moment. That's why I chose 'em
The bumper, a driver side door power window/power lock cluster, the dash, front bumper cover and rear bumper cover are being replaced from a buddies parts car of the exact specs as mine.
Old Jun 10, 2008 | 08:55 AM
MEZA TA's Avatar
looks good
Old Jun 10, 2008 | 03:16 PM
HibachiZ28's Avatar
Thanks man
Old Jun 11, 2008 | 08:38 PM
HibachiZ28's Avatar
Added some new photos and info.
Old Jun 12, 2008 | 01:15 PM
VIP1's Avatar
Copy & Paste Moderator
Originally Posted by HibachiZ28
I'll most likely be pulling the factory fogs and replacing them with 50mm micro projectors
You might be interested in Blazer fog lights:
http://www.hidplanet.com/forums/viewtopic.php?t=39583
http://www.hidplanet.com/forums/viewtopic.php?t=40777
http://www.hidplanet.com/forums/viewtopic.php?t=40506
http://www.hidplanet.com/forums/viewtopic.php?t=23810
They are rare and hard to find.
Check out the threads for some leads.
Or check the sales section here.
Or check ebay, but watch out for fakes.
If I remember correctly its a Halogen 894, but people have used re-based HID kits with success (check out the pics).
Old Jun 18, 2008 | 11:58 AM
HibachiZ28's Avatar
Thanks man. I am looking for them now. I pulled the factory fogs and I have a set of Blazers that I am waiting on.
Old Jun 18, 2008 | 03:12 PM
VIP1's Avatar
You're Welcome.
Please post up when they're installed.
 Michael S. Palmer
Old Jun 18, 2008 | 07:00 PM
transam5.7lt1's Avatar
They do light a lot better that stockies..... but I like more how square lights looked on 4the gen LT1's........ thats just my opinion.....
Old Jun 22, 2008 | 09:27 PM
VIP1's Avatar
.. Added to Lighting FAQ ...
Old Jun 24, 2008 | 10:47 PM
B4CZR2's Avatar
Just reading into this, any updates?
Old Jun 25, 2008 | 09:59 AM
  #32
ProjectCamaro's Avatar
Nice, when I had my '94 I always wanted to do that mod.
Old Jun 25, 2008 | 11:37 AM
  #33
HibachiZ28's Avatar
I'm still working on the bracket for the headlights and fogs now. But my t-top conversion has priority over anything at the moment
Old Jun 27, 2008 | 10:51 PM
  #34
HibachiZ28's Avatar
Added HID photos
Old Jun 28, 2008 | 12:33 AM
  #35
Firebird Phoenix's Avatar
Originally Posted by ndt/oos
now your fog lights dont match....
Thats what I was thinking, but the headlights look nice now. Gives it a modern touch, now update the fog lights too.
Old Jun 28, 2008 | 06:52 AM
  #36
VIP1's Avatar
He did:
https://ls1tech.com/forums/appearance-detailing/943767-added-projector-fogs-match.html
Old Jun 28, 2008 | 11:20 AM
  #37
HibachiZ28's Avatar
Yes, I added a photo in this post to show the new fogs too.
VIP: People on HID Planet are saying the output on these HID's sucks... check out the thread in HID Pictures/Video. heh.
Old Jun 28, 2008 | 08:28 PM
  #38
VIP1's Avatar
I posted.
Old Jun 28, 2008 | 09:06 PM
  #39
HibachiZ28's Avatar
Thanks, I just saw it. I need to cut the cut-off shields and level them out a bit. Did I mention my HID kit came with a broken bulb piece? The mount portion of it had busted either while being packaged or when it shipped. I was kinda pissed as I had installed the ballasts, igniters, etc. on both sides. Then did the bulbs in the housings.
I also noticed one of the housings was busted .. from a rock or something maybe? It was just maybe a 1"x.25" piece that was pushed in, so I got some super glue and JB weld and fixed it so I could re-seal the housing. I was wondering why it was fogging up!
So hopefully once I get the bulb back I'll be good.
I wish I had purchased a 4300k kit, but I was going on reputation of the company.. ugh. I did put a piece of white paper in front of it (the police test lol) and the paper remained white. So that's good, it's really not that blue at all... though the photos suggest otherwise.
Old Jun 28, 2008 | 11:11 PM
  #40
VIP1's Avatar
I didn't cut the stock shields. My brother and I made new ones out of sheet aluminum from Home Depot (it was about the same thickness as the stock ones). I think I need to make the entire shield about 1mm-2mm taller (or just elongate the mounting holes and move it up 1mm-2mm), which will block the bulb slightly more and lower the projected line (I think we revealed the bulb more than stock which is what's causing the orange burst on the passenger projector). We made the driver-side projector stepped and the passenger-side flat. The shield projection on the wall is the flipped image of the shield itself. To shorten the step, we didn't cut it as low as the stock one is cut. It took a while to get it right. We traced out the old one. Then layout out how we wanted the new cut-off pattern too look. To cut it out, we used tin snips to get close to the line and used files to get the shape down the line. It took some time and tweaking. Some people have instead added material to the stock one to get the same net effect. Also, to get the line as even/sharp as I could, after mounting them, I installed the H9 Halogen bulbs in the projectors and powered them up with a battery pack. To fine-tune the line, I push/pulled on the edge of the shield to improve the line and filed the edge to make sure it was as flat and burr-free as possible.
More discussion here:
https://ls1tech.com/forums/showthrea...ht=file&page=2
