Changing interior Lights - Help!
Old Jun 15, 2008 | 10:27 PM
98 WS6's Avatar
Default Changing interior Lights - Help!
Hey guys.. This may sound kinda dumb, but..
I'm replacing the interior lights with brighter LED's so everything looks less dull.
I did the overhead lights so far.. and I need help with a few things.
I pulled out the HVAC panel and looked at the bulbs. I can't figure out how the hell i'm supposed to get the bulb out of the socket. i didn't see any tabs or anything.. So i'm confused on that. Also, the door handle light, I took out the screw behind the door handle and pulled the panel back as much as I could (which isn't much) and cant really see how to get to the bulb. Anybody ever done this or can they help me out a bit? Oh yeah, I have 6 #74 LED's.. are the one's behind the gauges 74 too? And are they hard to change..
Thanks in advance
Old Jun 15, 2008 | 11:28 PM
mycamaroSS's Avatar
just break them and get pliers and pull on the thick wires. I had trouble with this as well but if you end up breaking the wire youre going to have to do a lot of digging to get most of the bulb out. Also you dont have to get the full bulb out if it does break just shove the led in as far as possible and keep checking if it turns on.
