Our answer to paint surface scratches
Old Jun 26, 2008 | 10:24 AM
ArcticZ28's Avatar
Originally Posted by The Alchemist
Well, I'm going to try out some of the Swirl Cutter Plus on my wife's Saab 9-7x that is black. I'll tape off her hood and use the two different orange pads and one will get the SCP from Tropi-care and the other will be the Menzerna Intensive Polish. I'm really hoping that the Swirl Cutter plus proves to be better on her car. I have a bunch of halogen lights in the garage, and it is dissapointing to see the swirls after spending hours on the paint.
Thanks Steve for the help.
Saab has pretty hard clear. Intensive polish isn't going to cut it - no pun intended.
Old Jun 26, 2008 | 09:43 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
The saab isn't too bad if I keep it outside and door pay too close attention to it.
But as soon as I pull it into the garage and the lights hit it, I see all the flaws in the paint and it drives me crazy. It's the last black vehicle I'll ever buy.
Here's a picture from the last time that I spent a good while getting the paint as clean and flawless as possible. Again, this is using intensive and final polish from menzerna using an orange pad.
It doesn't look too bad, but in a strong light, the flaws come out.
Old Jul 7, 2008 | 09:32 AM
UNDER PRESSURE MOD
Well, her car has spent a lot of time outside, especially this past winter as she has been working from home, so it got the bump out of the garage. I placed an order this morning for some swirl cutter plus, and with any luck, I'll be able to get her car back into 100% shape. I decided to order a micro fiber bonnet as well for the PC, so we'll see how that works out.
Old Jul 7, 2008 | 10:01 AM
Brian2006's Avatar
Seriously one of your best investments. Your arm will love it!
Old Jul 7, 2008 | 10:14 AM
loyolacub68's Avatar
I have a couple of those microfiber bonnets. Do you use these after using the swirl cutter to remove the remaining polish?
Old Jul 7, 2008 | 02:20 PM
Steve P's Avatar
LS1TECH Sponsor
Those bonnets are great for removing non-abrasive liquid wax or sealant residues. Place them over a clean orange foam pad for best results. Both sides can be used for safe removal.
To remove any remaining Swirl Cutter residue, use a clean damp microfiber detail towel or a quick spritz with detail spray.
