cleaning engine bays
Old Jun 21, 2008 | 09:20 PM
DSkyles's Avatar
Default cleaning engine bays
What do you guys use? And how do you clean it? (no water, pressure washer, etc.)
Old Jun 21, 2008 | 09:26 PM
homerunhtr21's Avatar
There is a sticky on the top of this section about this topic
Old Jun 21, 2008 | 09:35 PM
aothepresident's Avatar
GUNK engine foam. Spray it down while the engine is running, let it sit for a few minutes, then rinse. Be sure to cover fuse boxes, computer, maf, etc.
Old Jun 21, 2008 | 11:44 PM
Nauty99SS's Avatar
grease lighting , while engine is cool , then mist off with hose pipe, scrube the real dirty areas with soft brush , blow dry with leaf blower or compressor blowdown tool. don't spray streams , just mist and directly on computer and fuse boxes, use a little common since and you'll be fine.
Old Jun 21, 2008 | 11:48 PM
bene's Avatar
Trunion King
Degreaser, foam pad and water hose on mist. I let it air dry.
