Removing scratches from black paint??
MIP doesn't even compare to scratch-X. I don't even see what good people see out of that stuff. I've tried it before and couldn't get anything to work. If you have stubborn swirls, you might want to try Menzerna Super intensive polish as well
Regarding polishes, our Swirl Cutter was designed for use to remove ultra-fine lines from the finish especially holograms inflicted by high speed rotary polishers. Deeper lines inflicted from washing, drying and surface detailing may require the use of more aggressive polishes. Menzerna works quite effectively in removing these blemishes. The Intensive Polish ($25.99) will give you results on softer clear coats but may require more time and patience on harder clears. The Super Intensive Polish at $39.99 was specially formulated for use on these harder clears and will give you quicker response compared to IP. Recently we have also developed and released our new Swirl Cutter Plus($26.99 on sale now) for use on these more stubborn scratches.
Remember to use code "10offTC" on all orders over $50.00 through July and save 10%.
After completion of the SIP, any micro-marring or resulting fine haze can be eliminated with the TC-8 Swirl Cutter using your white pad.
Feel free to contact me with any other questions.
. In the meantime, I guess I could go ahead and order the sealant and accessories I need (pads, applicators, bonnets, etc). I will call you later on today to place my order. By the way Steve, how many times would you say the bottle of sealant would do my car (Black 02 WS6)??
