Painted lid question
Old Aug 22, 2008 | 09:58 AM
LILWS6's Avatar
Default Painted lid question
I painted my lid a while back and have no idea how to get it to stop rubbing on the hood. It wore thru the paint and the primer. so i want to repaint it but it will just rub off again i don't want to cut any of the hood. But i fear thats my only option anyone else have this problem and know how to deal with it?
Old Aug 22, 2008 | 10:27 AM
LS1Zedder's Avatar
Where is it rubbing? Mine was rubbing on the front right corner of my Z28 hood. I tried grinding down the lid and the inside of the hood and it still did it. I dont know if there is any 100 % fix for the rubbing. You may want to try moving your hood latch mechanism up a bit. That might raise the front enough to at least make it better. I dont know if adjusting the rubber stops would work cause of how the Firebird hood comes to a point between the headlights.
Old Aug 22, 2008 | 10:35 AM
travisnd's Avatar
get the blackwing lid, it doesnt rub
Old Aug 22, 2008 | 11:09 AM
WhiteFormula98's Avatar
its rubbing my slp lid also
Old Aug 22, 2008 | 02:58 PM
WS6_00's Avatar
is the lid seated properly? you'd be surprised. mine rubbed also and I swore up and down it was on right, ( until I learned) and now it doesn't rub anywhere. just my .02
Old Aug 22, 2008 | 07:21 PM
Nauty99SS's Avatar
i put a piece of the fuzzy side of velco tape on the hood so not to rub the paint off the lid ... works great
Old Aug 22, 2008 | 08:48 PM
raptorws6's Avatar
My slp lid rubs to and it is seated how its supposed to, I just try to ignore it. But I guess you cant if you paint the lid, good luck.
Old Aug 23, 2008 | 08:27 AM
Rokn Red's Avatar
Same problem here too, rub top right before the inlet into the MAF. What suck is i had it custom painted, this pic doesn't show it since it was taken it came home from the painter, but right above the the guitar head to the right.
http://i277.photobucket.com/albums/k...d/DSC00125.jpg
Old Aug 27, 2008 | 09:23 PM
LILWS6's Avatar
I had a problem with the filter not seating right forever so i had to grind down the tabs in the lower intake and now its fine but the rubbing persists. nauty where did you get the tape?
this pic is a while back before it wore thu completly but you can see a small white spot on the top just before in the slope into the MAF
Old Aug 27, 2008 | 10:42 PM
PontiacFan's Avatar
Any of you guys with the rubbing problem have the foam gasket from the K&N filter application in there?!?
If so, get rid of the K&N & the foam, & go back to a regular paper filter.
Old Aug 27, 2008 | 10:56 PM
panterx1's Avatar
I have the FTP Lid and did the same thing to mine with the velcro...no issues anymore. Worked great.
Old Aug 28, 2008 | 12:12 AM
samson_420's Avatar
I tried both, the K&N filter with the foam gasket and the paper one. Both rub bad. I was thinking of heating up the SLP lid and pressing that part down.
I just don't want to screw up my lid.
Old Aug 28, 2008 | 03:17 PM
unSStoppable's Avatar
ive seen that happen a lot too
Old Aug 28, 2008 | 03:58 PM
Nauty99SS's Avatar
you can buy it at wal-mart back in the sewing section they have widths
