Adding 26in skinnys up front
Old Dec 9, 2001 | 10:56 AM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
Default Adding 26in skinnys up front
will this help with the abs inop? How hard is it to slow down with skinnys? My rear ets are 26X11.50X15. They are higher then 26 though.
Old Dec 9, 2001 | 11:00 AM
Cool28's Avatar
Default Re: Adding 26in skinnys up front
also has anybody removed abs from the programming?
Old Dec 9, 2001 | 09:53 PM
DravenMyers's Avatar
In my opinion, it might work. Since they will ALMOST be spinning at the same rate it won't cause the lights to come on. But then again, your rear tires a just a bit taller, there's a good chance you'll set them off at very high speeds. I can't seem to make up my mind <img src="images/icons/confused.gif" border="0"> If you do try it though, keep us informed <img src="images/icons/grin.gif" border="0">
Old Dec 9, 2001 | 09:55 PM
oh, and about slowing down with skinnies. Yes, it will take your car longer to slow down. My low trac light comes on constantly <img src="images/icons/wink.gif" border="0">
Old Dec 9, 2001 | 10:54 PM
Terry Burger's Avatar
ABS is run by the BCM and its own computer, not the PCM. Just run stock height tires, I never have a prob with mine.
Old Dec 10, 2001 | 08:32 AM
7-LITRE's Avatar
When I switched from 165x15's to MT ET FRONTS 26x4.5x15 the ABS light went away. Haven't had any issues yet.
