Clay bar...
Clay baring a car is pretty easy to do. Just make sure the surface of the car is wet with the detailing spray that will come in the kit (both mothers and meguiars comes with it, the Zaino claybar will not come with an applicator spray, but thats no big deal.), take your time, and keep the clay bar clean.
You will be suprised at all the stuff that can come out of the paint. I did a C6 Z06 about 2 weeks ago, thought it looked pretty clean too from the beginning. It was garage kept, but driven often. I couldnt believe all the stuff I got out of the paint and how much better it looked after I got done.
Its well worth the money (meguiars and mothers clay bars are about $20 each), and can really clean up your car.
Good luck
- Mike
I always feel pretty pumped seeing the end result
After completion of the clay process on the paint and glass, lightly wash and rinse to remove the clay lube before drying completely.
To deal with light swirling and fine scratches, you can use the TC-8 Swirl Cutter. Minimal results by hand on just the lightest blemishes. Using machine methods such as the Porter Cable buffer will show real improvement. For deeper scratches, try Menzerna SIP or Tropi Care Swirl Cutter Plus.
For last step protection, you can select either the TC-2W "Crystal White" Carnauba Creme or the TC-3 Sealant xP on lighter colors such as your avatar. Feel free to contact us with any questions at toll free (866)341-0050 or steve@tropi-care.com.
- Mike
The paint was in really bad shape before we did anything to it.
3M makes some stuff called hand glaze, that fills in a lot of light scratches and swirls. It works pretty well before waxing.
The wheels were just sprayed with hot rims cleaners, and the tips were just me trying out some polish I bought at a car show. Clay baring a car is very necessary to do before a wax job. You don't have to work in swirls. Just get an area nice and wet with the clay lube and keep rubbing until you don't hear friction!
3M Imperial line. Awesome products as well. I buy 'em by the gallon.
